Jerky Arm Ape
I will be rebuilding my L31in my '98 yukon and would like to build it up for some more low end, possibly a little mid range as well.
I'm pondering on cam choices.
cam part # shouldn't have spaces, the format changes when I submit the post.
comp cams K08-300-8 cam kit looks like a good choice for what I want, all applications say that it is not comparable with my engine though.
1000-5000 operating range.
Hydraulic roller cam, (for 1987-1998 factory roller cam engines) 112 lobe separation, .450 in / .480 ex lift with factory rockers.
also is computer control capable
Comp says it gives great low end and mileage, doesn't require a perf. Tune either.
The k0 8 - 300 - kit & 1617-16 1.52 rockers + pushrods is well over $1000
I'm just wondering if there is an alternative cam available for lower pricing.
Also need header advise.
short tubes or long tubes?
-Pacesetter 2262 is the only long tubes I can find for 4wd chassis.
-shorts are very available.
Can't find any mid length headers anymore.
I will also be installing:
-delphi mpfi upgrade
-Volant CAI
-Possibly a v-max spacer
-New converters ( if I go with long tubes then I'm going to use flowmaster 2.5" individuals and have a shop pipe them in)
-Another dual exhaust with some type of performance mufflers (have flow master now)
-Volant CAI
