Cam
boomboom baker
Tennessee
I got a question I should have asked before I bought the cam I got a btr stage 4 cam man I feel stupid but is it alright to put this cam into my engine that has 238000 miles on it I mean this engine run great the cam is a choppy idle I have new valve springs that match the cam and should I do lifters Too
Not sure about lifters. Can't hurt. I think pushrods are recommended with the cam upgrade. Mine were done with my cam.
Had it to the track for some quarter mile passes?
Not yet. I'm not sure if I will tho. It's my gf's daily driver and we can't afford to break anything. I wonder if the sticky track would break something, because it's so sticky.
You can always launch from an idle so as not to put maximum strain on it, what you're after is the trap speed. That and a trip to the scales will give you your actual rear wheel horsepower.
bottomline2000
Dallas, TX
Lifters and valve seals while your in there. U don't want one with that many miles collapsing on ya. Definitely do hardened pushrods.
Sent from my SAMSUNG-SM-T377A using Tapatalk
Probably should do lifters with that many miles, agreed, along with hardened pushrods and dual valve springs and quality vitron valve seals. Unfortunately you have to pull the heads to do lifters, otherwise you can do everything else without pulling them.
Casper 2004 Tahoe
Definitely do lifters. I did not change the lifters in my Firebird and one of them broke a roller a couple of years later, which also took out the cam.
llisumm
