Can’t Fill Gas Tank
petethepug
Michael
SoCal
My fuelling issue wasn’t cured until the entire system was refreshed. It is a good bet to start with the evap purge valve at the filler neck though.
The savings come when purchasing your OEM fuel pump with a lifetime guarantee from PartsGeek or R/A. Find the least expensive charcoal canister (Amazon) evap purge valve & PVC (AutoZone).
Your 200k+ mileage says you have to drop your tank simply as overdue 100k maint. I used an Indi diesel tech to install and warranty the OEM parts I sourced and bought except the f/p as I was in a hurry. I paid $5h for a local OEM 09-14 f/p.
Initially I could only get 25 gal in the 30 gal tank. Restoring the system let’s almost 31 gal in now and it fills up to 30 gal without stopping. I used to take that for granted.
petethepug
Michael
SoCal
Ty! What a blessing to have it all behind me and forgetting. Fortunately, the forum info made it possible to repair with paying Zero for diagnostic time.
Having this info available as the carbon canisters failing at the end of their service life saves a lot of time & money for new owners.
Dustin Jackson
I am just reading through to see if you problem is similar to mine. I can't pump gas by letting the gas pump nozzle hanging by itself but if I lift the gas pump handle all the way up while it is in my Tahoe I can fill a whole tank without it clicking on me so now sure how the angle of the nozzle makes a difference...
Lets the air escape past the nozzle as it's pushed out of the tank by the fuel going in because the other means of venting aren't working?
petethepug
Michael
SoCal
Over the period of a year on our 09 Esky at 140k it went from like you’re describing to worse, to intolerable. By the time I hit 155k I had done my homework and started by replacing the vapor canister purge valve solenoid which helped slightly.
Only after the OEM fuel pump, tank cleaning, evap purge valve on the motor and carbon canister did fuel dispensing return to new car status again.
If you do it that order you’ll hit what IS going to fail soon as well as replacing the lowest cost items first and the bare minimum to correct the issue without getting hosed by diagnostic time.
iboughtatahoe23
i feeel like i have tried this, like moving it so air can escape. even a funnel doesnt work for me it still over fills
SpareParts
North Idaho
I had the same problem with filling up.
I read on here to try holding the handle pointing back instead of letting it hang there would help.
Holding it pointing mostly towards the back, I can fill full blast from empty to full with no stopping.
etreanor
