noticed on the scan tool that the cam retard was at -17 so i figured if i was going to be in there i would just replace the distributor, cap, and rotor anyways to be safe. and set the timing to 0, the original problem got a little bit better but it is still there, still no code. but now i have dead misses on 3 and 4 that started with the change in distributor and timing, replaced the new cap in case of an internal short in the cap but that didn't help, and if i let the truck warm up all the way and re start it the misses go away and the truck runs fine except it wont go over 3000 rpm. can someone explain what the tranny issues are that your talking about? just because i've run out of ideas. and i will check the ground next time i have time to get it on the lift. and thanks for all of the input so far feels like we're getting closer
---------- Post added at 06:07 PM ---------- Previous post was at 06:01 PM ----------
oh ant id doesnt die anymore that was only when it first happened but i was in the mud at the time, now it stays running but if i punch it it wont go over whatever rpm it feels like at the time and boggs and pops and sputters
