- Joined
- Mar 31, 2015
- Posts
- 121
- Reaction score
- 5
Ok wait. My blackout bowties fit inside the chrome cutout. So I guess I should clarify. Any way to remove JUST the gold inserts without drilling them out?
Thanks again.
In case anyone runs into this in the future, I think I found the answer and it is no. The gold inserts are glued to the cutouts with some black adhesive of death. What you have to do is drill a hole in the center of the gold insert (I did this while the front bowtie was still on the vehicle, I popped it off accidentally trying to get the gold insert out but in retrospect it probably would have been easier to drill and pry with the entire thing popped off and on a workbench).
You want the hole to be just enough to get a flat head screwdriver between the insert and the back of the cut out. (Incidentally I went too far before I figured this out and drilled all the way through the cutout). It's maybe 1/4" if that.
You then have to get a flat head screwdriver in there and work it around the hole on all 4 sides, prying. Eventually it will pop out. The thing that worked the best for me was to actually work the length of the screwdriver into the hole at an angle against the back of the cutout - the further you extend behind the insert along the left/right side of the bowtie, it will start to pop out.
Then razor blade to remove the adhesive and goof off. Wipe clean, remove adhesive tape on new inserts and pop those suckers in.
