Just Fishing
Can't fix stupid
I really wonder if I could just drill & tap the bottom of the cup (probably install a quick disconnect nipple) and have that connect with a hose to a bigger simple container that can sit on the battery box. Like a gallon of milk or Amsoil 4qt jug. These catch cans are in vacuum, correct? If so, then I’ll have to keep it from venting when the engine is on. I know that the manufacturer of the Yukon’s aluminum catch warns that freezing wx could cause their cups to crack open if not emptied. I just don’t want to dump this thing every few days.
Caffeine fueled posting; I do this often.
Sorry
I have been using these cheap ones i get off of amazon.
They fit this really nice morso mount, so i keep buying them.
They have a bolt on the bottom, but it's this funky metric thread.
When i installed it on my Tahoe, i decided i wanted to try drilling the hole out and attempt to thread it for pipe thread.
That allowed me to use a standard drain.
It went ok, I didn't quite have the correct drill bit to make it work.
but any slop that was there, I filled with a mixture of red Loctite and some creative staking from inside of the can.
Luckly it also has a removable bottom...
The can I keep buying (3 total now).
This thing is available from many different sellers and under different brand names.
No baffles in there, so I made my own.
Then topped off with some stainless-steel scrubbers near the top
For the intake side, I ran some tubing to get the vapors under the baffles and mesh.
Left plenty of room for a chamber for the fluids to sit at the bottom.
Nice part is the can itself is very thick.
Base and top, plenty of meat.
Very easy to do your own thing with.
And the bottom and top are completely removable from the main can.
Bad part is the shape of the top.
Takes space, so it must be mounted somewhat low.
I got creative and spent hours on it... lol
Skip this can unless you like tinkering with crap.
If you do go with it, shop around on ebay and amazon.
Lots of these are the exact same one
Prices and brand names vary like crazy.
This is the Mount I like.
Installed on my hoe,
Used hardline since i had a big roll of it handy.
the red stuff serves to keep things from rubbing together, and my flex joints.
On my wife's car, I got creative with some aluminum stock from my local hardware store.
Buick enclave with the 3.6.
Very tight under the hood!
I ended up breaking out my rivnut gun and mounted it underneath the windshield wiper area.
Right next to the master cylinder...
(Sealed the fk out of the rivnut install)
It was really the only space that would be easy to check, and access from the topside of the car...
