Catch Can ****
Just Fishing
Can't fix stupid
Utah
I get some ****** looking mud during the winter in my catch can.
It's just evaporating the condensation.
I have two catch cans on my Tahoe still, installed to test a theory.
I found the first catch can catches all the oil, sometimes a little milky looking during the winter.
the second catch can only get moisture!
Straight water. :jester:
Just Fishing
Can't fix stupid
Utah
I recently bought two more catch cans to try making one for the Jeep.
Another one of those round cans with the morso mount, and I decided I wanted to try this one since I liked the way it looks.
The round catch can I normally buy has one big disadvantage.
the drain port on the bottom is some weird funky metric thread.
so, I usually just drill and tap it for 1/4 NPT, then install a ball valve.
That works great but it's a big extra step and a pita for me.
I saw the square one with clear bolts on the bottom and the top to disassemble the unit, meaning I can make my own baffles easily and install them.
I figured wth, I'll give it a shot.
Plus, I can always find a use for a spare catch can. ;)
What I found is the drain port on the side is 1/8NPT!
I'm still on the search for a ball valve that fit's it, but for now it's perfect.
The "bad" the ports at the top still seem to be some weird metric fitting and not NPT.
I would like to one day make those AN fitting, but the nipples they provide seem to work good enough, and on this last catch can, I found I'm able to run some hard line through the larger sizes, then seal with Marine grade heat shrink tubing, then connect to the engine from there.
The issue I ran into with the Jeep, there isn't many places to mount anything.
there is a bunch of wasted space on the battery tray, but that's about it.
I found this catch can fit perfectly in the middle of some hoses and wires on that battery tray, so I decided to run with it.
One day I'll make a posting showing how I make baffles in the catch cans, but really, I just spent some time looking at high end (expensive) catch cans to see how they do it, and then work with that.
I had to take the intake off of the wife's Buick this past weekend, and while it looks like the simple design of that catch can I made for her car is working well, I did notice a tiny bit of oil in the return airline going into the intake.
This got me thinking about the design of the catch can overall. :)
The best working catch can I have made yet exists in the Tahoe as the #1 can.
That one built two chambers in the bottom of the can, one for the oil to sit in, and the one above it has some holes drilled into an aluminum sheet.
then in that chamber I made a little "fan" of sorts, copying my water separator that I use in my garage compressed air system.
I guess in theory it should make that air spin?
Or more likely the little blades help catch and separate more liquid from the heated air?
No clue!
but it works.
The bad part, I spent hours making that baffle.
And I have this super complex structure to help support that little "Fan" and to keep the middle chamber separated from the mesh that sits above it.
I had to break out the rivet gun to build it.
It's way over designed. :chair:
That's a one-time design, I don't think I'll ever bother making another one like that. :jester:
anyways, my rule is to always have fun with it.
donjetman
I'm gonna buy/put a catch can (small) on my 02 C5 corvette w/stock LS1 soon. It used 1 qt of oil in the 3k miles that I've owned it. Only has 63k miles. If necssary I'll put a better valve cover on it too. The catch can should tell the tale.
j91z28d1
I'd be interested to see where you put it.. I'd like to do my c6 just for the heck of it. it doesn't really use any except for mountain runs, lots of high rpm decel and 110k miles. I'll add a bit at the start of the mornings. but can't for the life of me find a nice spot and haven't seen any good pics online.
donjetman
space under the hood of vettes isn't as plentiful as our SUVs.
I may even do a combustion chamber/piston soak like I did to the Denali.
Just Fishing
Can't fix stupid
Utah
I have a PCV for a vette that I have plans to install in my Tahoe.
Pulls from the valley instead of the valve cover.
Seems like fantastic idea IMO since there isn't as much splashing around there (in theory).
I don't recall what year, but it might be a C6.
Just Fishing
Can't fix stupid
Utah
I have been trying to talk the wife into a C5 convertible.
She keeps thinking she wants a Miata convertible, but I don't exactly fit into one of those.
Like my knees won't clear the steering wheel?!
I'm not that tall, like 5'11, fkn weird cars. :chair:
C5 would be fun IMO, still has the fun flip up headlights that I love and it's an LS platform so you know parts are easy.
C6 would be better in the way that it's a Gen4 vs a Gen3, but still Gen3 stuff is super easy to get ahold of.
Wife keeps saying it's too long.
I just need to get a C5 vette and a Miata sitting side by side for her.
Or just do what I always do, buy it because of "Good deal" and toss her the keys when I'm done fixing it up. :boti:
As for a catch can, I haven't spent much time under the hood of a C5, but to me it looks like body panels will need to come off in order to find space.
On my C4 Vette, it was easy enough to find a spot.
Plus, the fenders come up with the hood!
As someone that grew up in the 80's and 90's, it's so sexy. :boobs:
j91z28d1
honestly unless you can go 08 it newer c6 when they got the ls3 and tr6060, I'd just find a clean c5 with the options you want. the ls1/6 are great. the ls2 of the early c6 wasn't much of an upgrade.
I still have a soft spot for the c4 about 86 with the tpi engine and a manual. never was much of a fan of the LT engines and the front and rear of the newer c4's, I loved when they were new, but the early ones look better to me now. next door to me at work had a manual 87 I think it was. total basket case, paint was shot but if I had a spot for it, I'd probably have another project lol.
j91z28d1
can't remember when I installed this catch can, I think it was a little before the last oil change about 1500miles ago. but checked it today, it was just touching the dip. it definitely had more than expected in it. no moisture, just nice looking oil. I feel like I want one for everything I own now haha.
wild.
mikez71
I wonder if mounting location makes a difference with the amount of condensation.
I suppose it doesn't really matter, but that you have to drain the can more often..
BLACKTahoe2016
