Chasing a rough idle?
2009TahoeLT
Also plugs are white which usually means it’s running lean correct? But then trims show its adding fuel. So I’m lost haha
rdezs
Plugs are white.... All of them? Well that would require combustion, which would require compression. I doubt you forgot to put on the intake manifold gasket? LOL. If you're positive there's no vacuum leaks.... Then you should take a close look at your fuel system including the O2 sensors. Plugged catalytic converters or muffler would foul your plugs black. If the fuel numbers are correct and it's running that lean, it's a very large vacuum leak. Try unplugging the large vacuum line to the power brake booster, and plug the port on the manifold. If that fixes it, you have a ruptured brake booster diaphragm.
2009TahoeLT
Yeah I had a huge vacuum leak and found the line to the charcoal canister was loose. Pushed it on tighter and smoke tested the system again. No visible smoke leaks and tank pressure was holding steady with vent valve closed. Intake manifold gasket is definitely in there. I installed the newer updated metal one.
I use copper plugs in my race engines
and
in my 233k mile 07 Toyota 4.0L since new, and change them every 50k miles. Cost as little as $4/plug :waytogo:
I seem to remember Richard Holdener dyno testing different plugs and gaps and nothing was more than 5 horsepower off the factory Iridiums.
What is to like about the copper plugs over the new stuff?
donjetman
Copper=Toyota FJ Cruiser oem in 2007, $4/plug, they work great.
Its never thrown a code, burned or leaked any oil, still has all original sensors, coils, etc, etc.
It's almost a NO mx vehicle
Copper is what everybody I know runs in their race engine(s) for the last 40 yrs. Again they work.
I don't run copper in my other vehicles :doh2:
2009TahoeLT
So small update. Here are the compression numbers. Now throwing codes for cylinder 5 misfire and also a p0300, bank 1 lean, oil pressure and a large evap leak. Motor bogs down bad when coming to a slow stop. When it misfires bad the engine light flashes and traction control turns off and stabilitrak turns off. The plug in the picture is cylinder 6 that has the highest compression. I’ve tried swapping plug, coil and wire with 5 and 3. It did not follow to 3. Just gapped all the plugs again. They were at .45. They are now at .40. Also cleaned out all the injectors. I did recently unplug the front o2 sensors and drove it a little bit. Seemed to have some of its pep back but was still misfiring.
2009TahoeLT
View attachment 453525View attachment 453526
Ok so also found the fscm fuse had a weird like burned grease film on it. Looks like previous owner put some sort of grease in it and it didn’t like it lol. Replaced the fuse and started her up. Check engine light immediately went away. Unfortunately still idles rough but is idling at about 580-620 which is better than the 480-520 before. Also still misfiring really bad on all cylinders at about 1100-1800 rpm
Katra1993
