Chinacargiags - "gm tech2 lacks the chips"
S
shegarty
Here is a direct source for Autel.
I am not the product expert. But, it looks like the ones that list "ECU" programming are the ones that are $2k+.
If you can't find something suitable that is already sitting at Chinacrdiags.com, cancel that and get refund.
If time is critical (or at least somewhat important to you), I would look to get a Tech 2 that is ready to go.
While the VXNano is a great option once it is installed and running... There is no way of telling how easy that process will go. You could end up farting around, trying to get the program running.
It really might be best to get a Tech 2 that is in stock and ready to ship. New or even used.
I would start with that OBD2 website and just get what you need and have it ready to go out of the box as soon as it comes in. And for $300 or so, we know what it can do, which is pretty near everything under the sun when it comes to our GM trucks.
Awesome - thanks for the info. Right now I'm leaning towards the VCXNano simply because I can get it for less than half the cost of any of the Tech 2 suppliers shipped to Canada (not to mention how much they will tag on at customs). Right now time is getting tight (summer road trip planned) but I think I should be able to get it done. I'm sure the community on here can help out where needed - they've always been clutch for me in the past.
exp500
Also inquire if there is a recurring license fee. Some have them.
You can run TIS2000 on a WinXP laptop; if using a more modern OS you'll need to set up VirtualXP and that can be a PITA but not impossible.
I can program through 2006 with my XP laptop, Tech 2, and TIS2000 (offline), but if you want to program later years you'll need to do it using Techline (online), still with a Tech 2 or VCX Nano but not using TIS2000.
the tech2 or tech2win can do what he needs to do, tis2000 is not needed. all that has to be done is a vin-relearn for the abs module.
S
shegarty
Is there a thread already created that details how this is accomplished? It’s for the airbag module not abs but I would imagine the process is pretty much identical?
ya I meant airbag, that was a typo
it's not hard to do at all, once you have the replacement module in you just turn the key on with th tech2 / tech2win running and go to the body control module and then srs system once you are in there you will see a option to vin-relearn the module. that's basically how it goes, the srs system could be in another place on the tech2 it was while back when I did mine but if you just poke around the menu's you will find it, the options are not endless on the tech2, it only has so many choices if you don't find then just back out and pick another one. If I get a chance I will try and make a video
S
shegarty
Awesome, sounds pretty straightforward then. I’ve ordered one of the VCXNano’s but it won’t arrive until next week. I’ll do some poking around as well for other resources in the meantime. It’s always good to have multiple sources.
Scottydoggs
NJ
that will not work for what he is trying to do, pretty sure it does not read abs at all either, none do over bluetooth part of the reason being abs/srs are not OBD at all.
i have that app. it scans everything. srs abs p and c codes and will clear abs code history. also does live engine data.
nobody I know or have seen has been able to get abs/srs to come up with any bluetooth adapter, it supposedly works on other makes or brand vehicle but not on GM, I have a gang of bt obd adapters and have tried them on a variety of app's, maybe i am doing something wrong
drackill1
