chirping like a nextel lol
blue99tahoe24
blue99tahoe24
bout that tahoe life
joliet il
did not do idler yet and yea i sprayed it i think it mite be a mis alignment in the pullies
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Maybe this. I know it does not apply to 1999 from a factory done PS pump but perhaps it might have happened later if pump was changed.
Engine - Drive Belt Noise, P/S Pump Pulley Misaligned File In Section: 6 - Engine
Bulletin No.: 77-60-02
Date: June, 1998
Subject:
Accessory Drive Belt Noise Due to Power Steering Pump Pulley Misalignment (Properly Align Pulley) Models:
1996-98 Chevrolet and GMC C/K, M/L, S/T; G, P Models
1996-98 Oldsmobile Bravada
with 4.3L, 5.0L, 5.7L and 7.4L Engine (VINs W, X, M, R, J, N - RPOs L35, LF6, L3O, L31, L29, L19) Condition
Some owners may comment on accessory drive noise.
Cause
The power steering pump pulley may be misaligned with the end of the pump shaft.
Correction
78220605
78220606
LI99HOE
Top Notch Tech.
N.Y.
So other parts besides the belt, and tensioner were changed, or was it only those 2 parts?... knowing this def. helps narrow down the suspect.
Sunlit's post about the pully misalignment is gr8 info.... I'll have to keep it in mind when mine's gotta be done.
blue99tahoe24
blue99tahoe24
joliet il
i think i figured out my problem guys i was trying to find out the chirping problem and i think i spotted i while the truck was running i was looking at the pullies and the crank pulley was wobbling so im going to change the crank pulley and the harmonic balancer i even looked at a suburban wit the same engine that came in my job today and his wasnt moving like mine has anyone changed these before??
---------- Post added at 10:09 PM ---------- Previous post was at 09:41 PM ----------
and do i need to change the crank pulley do they warp or is it just the balancer
blue99tahoe24
blue99tahoe24
joliet il
i think its a end to the madness after a harmonic balancer idler pulley a tensioner and a fresh dayco belt started it let it run for 20mins no chirps let it sit for 2 more hours started with no chirps thanks for all the help guys
blue99tahoe24
blue99tahoe24
joliet il
i think ima try that goodyear gatorback belt i hear its the best i just dont know where to buy
BOOM360
Just curious if you replaced the crank pulley along with the harmonic balancer? Is it still wobbling? I've had an intermittent squeak/chirping on my '99 Tahoe for the past couple months that recently became pretty constant. I replaced the tensioner, idler pulley, and belt but it was still there. Thought it was a bad bearing in the alternator but guy at the rebuilders said it wasn't. When looking at it we noticed the crank pulley was wobbling slightly, which might be causing the belt to squeak. I took the pulley off, cleaned the grooves, and looked it over and it didn't appear to be out of round. I did some research and found that the problem might be the harmonic balancer. Since my truck has 140k on it I decided to replace the balancer for $40. Noise is still there...and my next move is to replace the crank pulley but I have to order it. If that doesn't fix the wobble I'm worried the crankshaft might be the issue. Were you able to get your noise fixed, and do you have any other info on what to look at next? Thanks
gseling
