Code check!
dsltrc
Virginia Beach, VA
So i've been having some small problems and went to Advance to use their sanner, came up with a few codes, P0118 (Engine Coolant Temp Sensor) i have plenty of coolant so i'll just replace that tomorrow... but the one that is getting me is the B0281 code.... i have googled and i can not find an definitive answer. All my brake lights are working and my ABS light has not come on except at start up (which is normal)... can anyone help?
ch4d
A Podunk town in Oregon
here is what i found
DTC C0281
Circuit Description
The stop lamp switch signal informs the electronic brake control module (EBCM) when the brake pedal is pressed.
Conditions for Running the DTC
Either of the following conditions will cause the DTC to run:
The ignition is ON and the vehicle achieves at least 56 km/h (35 mph) before coming to a stop.
The ignition is ON and the vehicle experiences an antilock brake system (ABS) event lasting at least 1 second.
Conditions for Setting the DTC
The EBCM detects an open or shorted brake switch or brake switch circuit.
Action Taken When the DTC Sets
The EBCM disables the VSES.
The message center displays the SERVICE STABILITY SYSTEM message.
Conditions for Clearing the DTC
The conditions for setting the DTC are no longer present and you use the scan tool Clear DTCs function.
Diagnostic Aids
Thoroughly inspect connections or circuitry that may cause an intermittent malfunction.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
And that would be appropiate if it turned out it was a c-code but I will wait for verification before I start throwing out code descriptions to him.
dsltrc
dsltrc
Virginia Beach, VA
Well I went to advance after I replaced the ECT sensor and its no longer showing the codes... So unfortunately the B0281 code shall remain a mystery... But thanks for your help guys...
Garage2010
