Codes P0050, P0059, and P0155 2010 Yukon Denali XL
Fubar0715
Scott
Southern New Hampshire
I literally changed the up stream O2 sensors last week. I had the P015 code for both sides and decided to do them at the same time. I think I got the parts from RockAuto shipped for about $80. The socket was picked up from Harbor Freight for $8. You will need a 3/8 ratchet and the socket along with a short piece of pipe to get extra leverage on the ratchet. TBH, if I knew exactly what to expect-would have taken an hour, tops! Additionally, didn't need to jack up the truck or put on a lift. Easy Peasey!
91RS
GA
Those are all for the bank 2 sensor 1 oxygen sensor so in this case it is a fairly reasonable assumption that sensor is bad. I would go ahead and replace both pre-cat sensors. Use ONLY GM parts here.
Hobbitsam
