coil over conversion installed
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
30 ft lbs on endlinks
Also is it the double or single adjustable qa1
04blackout
04blackout
Just for grins I figure that I'd ask...Have you've considered the 6" drop springs that Tony has for sale?
Yes I have, and I will be using them once they are available again... hoping those springs with the stud top front mount will let me go a little lower and not destroy my ride
04blackout
04blackout
Well guys, I *THINK* I found the problem that was causing my rear sway... looks like I need new rear sway bar end links
digitalfiend
Expert Overthinker
San Antonio, TX
"WELL THERE'S YOUR PROBLEM" :) Seriously, glad you found that. That may not be *the* problem, but it's definitely something that you needed to find.
Just wondering, Why do you ask that?
Because they rock, that's why.
I want to have them ready to ship this week. I'll PM you in a few days once I hit another milestone.
Tahoewhat
Ballin' on a Budget
TX
I knew it had to do with the sway bar area. lol. Glad you found the problem and got a pm coming your way.
Just wondered, I love my 5305's, just wondered why the change.
04blackout
04blackout
I seriously can't imagine how this happened. When I say they weren't very tight, I mean by my standards, and ive been known to twist bolt heads off with normal 1/2" drive ratchets, so its not like they were super loose... only thing I can think is when I swapped out bolt hardware to "get rid of the slop" maybe I forgot to tighten that one, but still crazy the whole bushing came out too. I found this when I got under the truck to change the oil tonight, and was like hmmmm something looks weird back there...
Tahoewhat
Ballin' on a Budget
TX
ha ha.. Something looks wierd. Yep....
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
that will happen when bolt comes out. The sleeve falls out and bushing just twists and twists and falls out
BTW my springs are in stock
Alphamods
