Comp-Temp Display is Very Dim
Rivieraracing
I just re-soldered mine tonight, hopefully will have positive results tomorrow!
Thank you for sharing the info on this simple repair.
Awesome man, hope it works for you like it did for me! Check back in with your results if you don't mind!
grizzy
Maine
Well, went over each solder point with the iron until the solder bubbled twice last night. Took the Yukon to work today, and still have the same issue with the compass/temp blinking and turning off and re-setting. I might try to resolder the contacts later, but unsure if this will resolve the issue with the mirror. It was worth trying!
Rivieraracing
I wonder you have a different issue than what I had, mine would never act like it was shutting off and resetting. I'd be checking for power at the plug to make sure you don't have a loose connection!
---------- Post added at 06:36 PM ---------- Previous post was at 06:35 PM ----------
....or it also might be different joints in the mirror that might need to be resoldered. Check it all out and see if you have any other obvious cracked solder places!
SoutherlyAlloy
