Complete "Spongy Brake Feel" Write-up
S
sparg93
Expedition Tahoe
NJ
Pulling the ABS fuse...i might have to try that.
My tires are only slightly wider then stock (16") and it killed me b/c my 3/4t calipers can barely get them to pulse. From your photo i can tell you're running larger tires which should make it even harder to lock your brakes....and with the improvement you saw, I'll have to git it a try.
I don't know if i can do it this weekend, but i'll pull the fuse when I can and revert with the results!!
I'm still VERY interested in boosted brakes or larger master cylinders, so if anyone has research or ideas, please share them!
96ProCompTahoe
IN
not sure how much the pulling the fuse will help on a stock gear ratio truck. mine is varied enough the ABS doesn't work correctly and would randomly almost cause an accident....
S
sparg93
Expedition Tahoe
NJ
Time to bring this back from the dead with results!!
Due to me being solo for this and a lack of any scientific equipment other then a wheel with a built in counter (no idea what it's called), these numbers have a high chance of error...so please don't take these stopping distances (60mph - 0) as gold. What I think is important is the changes between and overall average of each setup.
Vacuum, 1/2t calipers, 1/2t pads, 265 tires, stock height
1st pass - 138ft
2nd pass - 136ft
3rd pass - 135ft
Vacuum, 3/4t calipers, 3/4t Hawk LTS pads, Slotted rotors, 265 tires, stock height
1st pass - 146ft
2nd pass - 148ft
3rd pass - 142ft
HYDROBOOST, 3/4t Master, 3/4t PS pump, 3/4t calipers, 3/4t Hawk LTS pads, 285/70R17, 4.5" lift
1st pass - 134ft
2nd pass - 130ft
3rd pass - 129ft
Surprisingly, each day I did the testing, it was about 50deg.
Additional info:
- My shocks were not setup correctly when I did the hydroboost passes, so with firmer valving, I have a feeling a few feet will be knocked off
- During the hydroboost test, my truck was a few hundred pounds heavier with the lift kit, bigger tires and tools in the back
Some observations:
- DO NOT BUY 3/4T CALIPERS UNLESS YOU HYDROBOOST - you're stopping distances will INCREASE. Also, the 3/4t master will not bolt up to you vacuum system
- Hydroboost was able to finally lock the tires and create a small patch of rubber...my vacuum was not able to do that
Some negatives:
Using all new AC Delco parts (do not buy cardone), expect to spend $750+ and three days doing this for first timers. You're upgrading the master cyclinder, PS pump, hydroboost unit, GM variable assist bypass, three lines and possibly adding a Power steering cooler...this stuff adds up really fast. You can always go used and ppl have had a lot of success, but for brakes, I personally always buy new.
Hydro units have a propensity to leak and are expensive to have rebuilt. If you buy used, definitely get some kind of guarantee that if it leaks, you can return. My first (new AC Delco) unit leaked and it took a week to get another one...
Also, you will need to cut and re-flare brake lines...so definitely know what you're doing before you rip into your truck's braking system. This is a job that is straightforward, but definitely requires someone who is comfortable working on multiple components and understanding when something is installed correctly (i.e. always replace orings, use line wrenches and torque to the correct settings!)
Everyone has a different preference, but I really hate that i lost variable steering. My rig rode like a boat prior, once I bypassed my variable assist, steering got even softer. With the months of research I did, I could not find a hydroboosted truck that had variable assist....so plan on bypassing it b/c otherwise you will restrict the amount of fluid your hydro unit receives.
I hope this helps everyone in the endless quest to stop these rigs! Please feel free to ask any question you may have!!
Part #'s:
Power Steering Return Hose - AC Delco 36-368640
Power Steering Pressure Hose - AC Delco 36-365460
Power Steering Pressure Hose - AC Delco 36-365490
Power Steering Pump - AC Delco 36-517137
Master Cylinder - AC Delco 174-722
Hydroboost Unit - AC Delco 178-578
Variable Bypass - GM #19168825
OEM PS Cooler (from gmpartsgiant) - 26041420 & 15655032 (bracket)
A good writeup for the install - http://www.gmfullsize.com/forum/showthread.php?t=156800
kaiwren986
Wow nice work. Almost does seem worth it.. Unless Im towing or something, then I imagine thats where the improvement will really come into play.
S
sparg93
Expedition Tahoe
NJ
I'm towing for the next few months up/down mountains, so we will definitely see how worthwhile this mod was!!
The one nasty part of this mod is that a grain of sand entering the system can cause the hydro to leak...so be VERY careful when you install and pay incredibly close attention to make sure when the PS pump cap is off, nothing gets in.
Some guys install inline filters to reduce the chances of this happening. I personally did not do this, but when I get back from my trip, it will be high on my list. I'm crossing my fingers that my unit will not leak until then.
BurbyRST
