Compression Testing
raptorforme93
Tampa, Fl
When I replaced my lower intake gasket, it was separated and falling apart and in really poor condition. I wonder if that really is the result of the acidic dexcool antifreeze. But either way, no one brought up the lower intake gasket going bad because you never listed any symptoms or what was happening to the truck or any details. Also, the lower intake gasket going bad will not cause the truck to run or idle any differently or any of the cylinders to lose compression. It will cause your truck to overheat and lose cabin heat though
crxx
tn.
you probably aren't seeing any leaks because it is possibly going out the exhaust like mine was a few weeks ago. i was wondering where it was going....when the gaskets did go completely it was mixing with the oil.
L
LVNeptune
#2 135
#3 140
#4 130
#5 115
#6 130
#7 130
#8 150
Readings they gave me.
neilreuben
