Confused about lowering
popo8
popo8
Ok. Soon as i have it
LTXtech.com IS my drug...
popo8
popo8
Ok... 1st thing that needs to be addressed
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Ask them if they
1. Took off the rear sensor lines on outside of frame whwn they dropped rear end to put springs in. If y
Nit could of snapped a line
2. In rear how did they adjust the autoride links. I've seen shops adjust them on the truck and break the sensor
3. In front make sure the autoride connections are on. If they forgot to put it or or forced thrm.on from a angle could have damaged them.
I'd just take it back have thrm check it out becuase somethings not right.
popo8
popo8
I took a screen shot of ur post and sent it to them. Its aft hours now so may not hear till 2moro. Other than the light it def rides tighter. Have not bottomed out yet.
I have not heard the comprrssor at all either. Im guessing maybe the switch/sensor may not have been modified....
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Its prob not coming on because somethings messed up. If they didnt move the rear autoride links then the compressor would kick on all the time. Im sure they will fix whatever it is. What kit did they use on it?
popo8
popo8
Belltech
---------- Post added at 08:32 PM ---------- Previous post was at 08:31 PM ----------
Oh they will def make it right, i just want that light to stop staring at me, lol
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Wait why did they use nitro shocks??? That kills the autoride.
They bypassed your autoride that's why you have the sign on dash since they got rid of all shocks. Was your autoride working fine before??? Did you want to keep autoride?
popo8
popo8
I did want to keep the aito ride. Nothing is removed. Its all still there tho?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
On their page they said "nitro drop shocks" which are replacements. They sell the nitro 2 and the belltech sp which sp is much better.
If you have the truck with you check to see if the rear shocks are new. They said nitro shocks so im guessing they took your autoride shocks out.
popo8
popo8
At least I thought so. I will get under it in the am and take a look.
---------- Post added at 12:28 AM ---------- Previous post was at 12:26 AM ----------
Ok, good info. Its out in the dark now. 0026hrs here in PA. ILL take a look first thing in the am.
I did screen shot ur post and send it to the owner of the business now. I let him know if thats the case, this needs to be reversed.
Or in ur opinion is it ok without it?
What am I losing by replacing the auto ride with the nitros?
---------- Post added at 12:59 AM ---------- Previous post was at 12:28 AM ----------
I guess what Im asking... am I really losing anything by not having the air ride? I guess i was stuck on keeping it, cause its part of what makes it the caddy and not NOT a caddy.
If the nitros replaced it, technically i can remove the compressor amd stuff now right?
Guess it also means I coulda gone with more drop? Lol.
Is there a way to kill the light (i guess i only need to worry about this if ur answers to the previous are not negative or detrimental to the ride or safety.
Fyi... i launched it over some rail road tracks and do think i bottomed out... but it def took aggressive drivinh for me to do it. Lol
cuttingedge
