Console/Bose Harness
Musiqizme
Hi does anyone have the wiring diagram for the 2005 denali center console? I have a 2005 yukn slt with a non premium bose system in it and I put a 2005 denali center console in this past weekend with the premium amp, needless to say it doesn't work, nothing works not even the cigarette outlets. I looked at the center console wire harness and it fits but has way more wires than my non premium bose sytem harness, so I believe I have to do some rewiring which is fine but I need to know what wires are which so I can get my amp and power outlets working, that's all I need.
YukonXL04
The Riverboat
Arlington, TX
I just did that swap on mine. I only hooked up the power outlets, I have no use for the bose amp.
However I believe if you search for a amp bypass diagram you will get the wire colors needed
As for the outlets, I cut all the plugs off the harness then soldered a length of wire to it and hard wired that into my old cig lighter wires. Orange is + and black is -
D_dontknow
