Control arms
kbuskill
NE. FL.
Do you have steel or aluminum knuckles? If steel (cast iron), you can convert to cast iron lowers from cast aluminum without having to change knuckles. I think.
Were aluminum knuckles/spindles even available on the GMT900s???
I thought the the ones @randeez used were from a '15+ Silvy.
I don't remember anymore Ken. I wrote this down a few years ago, it was next to a heading for a 1500 4WD and GMPartsDirect says it will fit mine.
Frankly, I don't even know what I really have! LOL They (knuckle and lower CA) look aluminum but magnets stick to them.
Dustin Jackson
@kbuskill I think they are, Rough Countrys forged upper control arms comes with additional hardware in case you are using an aluminum knuckle. @swathdiver had the correct information that I had mixed up, the steel VS aluminum KNUCKLE is what I was thinking about, not steel vs aluminum sontrol arm.
randeez
south florida
i knew some years gmt900 had some aluminum control arms/spindles, it uses some mismatched ball joints and tie rod ends though, it was easier just to order all of it from a 14+ truck
jkssv08tahoe
I just did mine over. Since my truck came from Vermont and now has 160k on it. The bushings were shot and arms rusted badly. So I replaced them and had to cut one out with a Sawzall since the bolt was fused into one bushing. I just went with the steel ones. I did notice the aluminum ones since I do a lot of Mountain biking and I have to do some off-roading to get to trailheads. I figured the steel was the way to go. Since I was there I threw on two new hubs also since I had no clue if they were ever changed. Also New swaybar end links, rotors, and Calipers, and hoses too.
Nemo_B4
