Coolant Drain Plug on Block...2012 / 5.3
blondie70
Howdy. Anyone know the size of the coolant drain plug? I can only see one on the drivers' side of the block. Appears to be a hex recessed type plug that needs a "giant allen wrench" to remove.
Next coolant flush, I want to remove it to make the flush a better one.
Thank you...Pete
Big Mama
Virginia
I’ve never heard of it being done that way but I’m no mechanic. It seems a little dicey opening that up. A traditional flush should accomplish the same thing but I’ll be watching this thread to learn something new.
strutaeng
Dallas, Texas
I bought this kit specifically for that plug. It's the largest or second from largest, so either 14mm or 17 mm.
My LQ4 I'm currently overhauling had a block heater installed there. I removed it and installed the brass plug (had one laying around from another engine teardown.)
Just reinstall it with thread sealant and torque it to spec. I think it's like 40 ft-lb, but don't quote me on that.
Blackcar
These Allen wrenches in link with ball end a lot of times let you remove hex plugs when obstructions are in the way of removing.
Just Fishing
Can't fix stupid
Utah
I don't remember the size, but there is also one right above the starter (if memory serves me)
Otherwise you will have half of a block full of coolant.
When refilling, be careful of the thermostat.
if it's not one of those that have a little valve built in, they will trap air and not let it fill to the heads.
One of my neighbors blew an engine doing that.
B
blondie70
Hi Fishing.....wonder ...can one pull the plug above the starter without pulling the starter ? I looked up there and never saw a plug...Thanks for the info.
B
blondie70
Wow ! A kit just for one socket. Oh well ...maybe I'll make one....a piece of bar stock...a grinder and a stiltson wrench. What could go wrong ??? ha ha ha......thank you.
strutaeng
Dallas, Texas
Yeah, I bought that socket set because my other set didn't go that big.
So it's a 17 mm on that large one. I actually didn't remove the one near the starter side (I just painted over it too). I checked and that one is a 8 mm.
Photos for reference.
Chineyfari
