crank cam correlation help
robhenry2990
Pittsburgh PA
so i had it scanned and it is -1. now i read somewhere that in spec is 0 to +2. how do i fix this? i read turn the distributor, but i thought that the distributor only goes one way. with everything at top dead center the pointer points to cylinder 1 so i think its on the right tooth. and it runs like a champ. i just replaced the distributor and i marked everything. please help this cel is annoying
SunlitComet
OBS Jedi-Do Good
unknown at this time.
No you don't your spec is fine as long as you got that spec under the required engine speed for data acquisition. The specs are 0.0° +-2.0° so anywhere from -2.0° to +2.0°. If there was an issue the pcm would notify you.
robhenry2990
robhenry2990
Pittsburgh PA
well i got a cel for crank cam and the tech told me its -1 out of spec so i guess its -3 then? and what do i turn?i asked him and he said he couldn't tell me that i had to get the service done. if i turn the housing the bolt wont line up unless i turn it 90*.would it turn that much?
---------- Post added at 07:49 AM ---------- Previous post was at 07:32 AM ----------
"Once the distributor is fully seated, align the distributor rotor segment
with the number 8 pointer that is cast into the distributor base.
If the distributor rotor segment does not come within a few degrees of the
number 8 pointer, the gear mesh between the distributor and camshaft may
be
off a tooth or more."
is this right?
robhenry2990
robhenry2990
Pittsburgh PA
the distributor housing only goes in one way thats the only way it will bolt up unless i take the too torx bolts out of the rotor and turn that by its self. i also read that there should be a white paint mark on the distributor and that the indent in the dizzy should line up with it
http://autorepair.about.com/library/a/1a/bl340a.htm (step 2)
i dont have a white mark on my new distributor
and step 6 im a little confused about the tab should be within a few degreess of the pointer what if its not? how do i fix it?
SunlitComet
OBS Jedi-Do Good
rob change your hold down bracket to the one with out the long forks. that does not look like the oem hold down to me.
---------- Post added at 05:47 PM ---------- Previous post was at 05:41 PM ----------
it should look something like this.
attachment.php
Ceejkay
Ft. Lauderdale, FL
yea that looks like the wrong hold down bracket.. hit up a jy for it and look for any 350 with a dizzy and it should look like the one in suns pic
haloOne
