LOL, That hold down bracket Sunlit is suggesting is for a Pre-96, that intake is a TBI (pre Vortec) intake. The hold down bracket for the Vortec distributor is different. The Vortec housing has squares on it to minimize cam/crank issues WHEN the distributor is installed correctly.
That is the base of a stock Vortec distributor, you have the right hold down ...
Here is a stock Vortec distributor with the CORRECT stock hold down, see how it sits in there, there should be no adjustment:
Basically it boils down to this, you didn't zero your engine correctly when you dropped the distributor in. I can tell by your comment "the distributor only goes one way" ... the engine is supposed to be at 0 degrees when you dropped that new distributor in. You need to adjust the oil pump shaft to get your distributor to lineup correctly since there is not supposed to be any adjustment at the distributor cap like on "old school engines".
