Cranked keys. How do my Suspension angles look?
Epik
So I just did a complete overall of my suspension & steering components, including Moog front end parts, Bilstien 5100’s front and rear, cognito pitman/idler braces, and also had the mechanic crank the stock keys a bit. It’s not completely level, but I’m now sitting at 37” in front & 38 1/4” in the rear, looks much better, but definitely feels stiffer (not sure if I like the ride yet). Hard to tell if it’s from cranking the keys, or if it’s the Bilstien 5100’s & a combo of everything being brand new underneath. My truck has 263k miles, so my suspension was definitely worn prior to this. Anyway, how do my suspension angles look? Should I be worried about premature wear on my components, or bottoming out on the frame stop? There is definitely still a decent little gap between the Uca & the frame.
A861A8EA-3149-432A-9646-109A21E92E95.jpeg 7B352811-293A-4C97-92CE-0A22EE879826.jpeg 53F0A8A0-1D7C-4CDA-A4F7-B77186998A8D.jpeg 4CF8D31F-EF58-4E31-BDBF-B7E6541A16B1.jpeg A7EEDD2B-6203-4DB7-A07D-47AAAA06193E.jpeg
Countryboy07
Look good to me, I wouldn't be worried about any pre mature wear
Epik
Epik
Isn’t perfectly level, but before it was about an inch lower than it is now in front.
6EAB0C84-2955-469B-B40A-1ACE3F022CC7.jpeg 4724289E-7E79-4F06-8643-99BB7BC1386A.jpeg
Epik
Epik
Thanks! Not too sure if I like it with it cranked, ride is noticeably stiffer, but I also went from Bilstien 4600’s to 5100’s. I’m gonna feel it out for a while. 1/2” more in the front and it would look even better, but I know it will make the ride worse, and I doubt my stock keys even have that much more in them.
richs1
You’ll get used to the ride and before long it will feel like it did before....at least mine did. Unless you are doing extreme hard off roading, suspension angles won’t cause too much of an issue. I have aftermarket keys and spacers, I am at about 39.5 at all four corners.
Epik
Epik
Yeah, I don’t even off road at all. I would like to go up another 1/2” to get it close to even, but don’t want it any stiffer then it currently is.
Epik
Epik
Are you running aftermarket upper control arms? That seems pretty steep in front, from what I’ve read?
richs1
I have the same truck and mine rides fine. I really don’t think it will be any stiffer if you add larger keys and spacers.
Epik
Epik
I don’t want the rear higher, just want the front to be about 37.5” or 38”
quicks hos
