Cross-Posting my Reduced Engine Power Thread - Need help!
Mighty Hd
Florida
Cross-Posting this as I need a bit more exposure to this ongoing saga. Any help is desperately appreciated, I am out of ideas other than a trip to the dealer at this point. :-(
BG1988
i would check the throttle body and the wires & gas peddle REP code is tied into that..
when i disconnect the Throttle body power cable i get that message
one of the Thorrttle position sensors are acting funky bad bad wire, bad ground
in a OBD2 reader that has live data you can see if the throttle position % changes when the gas is pressed
one of the 5v lines might be grounded out or not functioning (it has 2 on the throttle "aka gas peddle" and two on the throttle body ) this is to prevent a malfunction engine run away condition.. or gas peddle issue when one of the resistors go bad from being worn out
see page 6 #28 here to diagnosis it
Snowbound
Jim
Chicagoland (Lockport)
I’ve seen similar issues on a buddies ‘10 Tahoe. He was told by multiple shops it was the BCM causing his issues. Same thing, cleaned grounds, replaced battery, even did ground cable and issues would come and go. He changed the BCM and had it programmed and it ran great for a few days. Seemed like everything he did or shop did would make it run fine for a day or two and made him think it was fixed. Then go back to reduced power, limp mode. He was finally able to drop it off to me so I could do some testing. Ended up being a $25 termination resistor in the harness above the spare tire. I thought he was gonna kiss me when I told him I fixed it.
Snowbound
Jim
If I remember correctly he was having communication issues between modules and high and low voltage codes to different things. It’s been a while but that termination resistor is an important part for the LAN cables. There should be a resistance you can look up to confirm yours is bad but I think his read “I” for infinity meaning open. Be an easy test. It’s wrapped in tape to the harness above the spare. There are at least 2 in the system. But the rear one would be your issue if any I believe. Good luck and I hope this helps.
M
Mighty Hd
Florida
I have replaced:
MAP
Mass air flow sensor
Throttle body
Gas pedal
Fuel pressure sensor
Fuel pump (low pressure)
Negative battery cable
Positive battery cable mega fuse 170a
Fuel pump control module
Ground strap from the firewall to engine block
All 4 O2 sensors
All grounds have been cleaned and /or new terminal ends installed
- LT/RT front frame rails
- under driver door
- LT front dash near the pillar
- LT rear frame rail ground
- RT dash under the side cover
Wiring harness has been checked top to bottom.
I have a new ECM ..pending dealer scheduling to install.
I’m seriously ready to sell this POS. At 90k I shouldn’t be having these issues.
Just for the hell of it, I ordered the resistor posted above..
Snowbound
Jim
That’s one heck of a laundry list of parts to throw at it. Not being a smart guy here, but what I see missing from the post are things you’ve actually tested. Just the cost of parts alone would have been money better served taking it to someone who can do proper diagnosis. I sure hope that resistor fixes your problem just for your sanity. And it’s only $22.
M
Mighty Hd
Florida
Minus the cost of the ECM, I have around $350 in parts so not too bad. Between coupons and getting some of the parts at cost has helped.
M
Mighty Hd
Florida
Installed the resistor today.
Engine Power is reduced message does not appear with the factory tune installed.
The instant that I put on the blackbear tune, and even before I start the vehicle (key to ON) the EPR message appers.
I have a few messages into Justin @ Blackbear. I'll update the post when he replies
BG1988
the GAS peddle it self will throw the REP code CHECK with the OBD2 reader to confirm it's funtional
Tahoeminer
