Exterior:
U2-35 24x10 wheels
Nexen Roadian HP 305/35/24 tires
SS front bumper cover
Body colored grille and bowtie
Street Scene speed grille inserts
HD hood
Street Scene rollpan
Street Scene flip-down liscense plate bracket
Sir Micheals hidden hitch
Badges and side molding stripped
Removed radio ant and On-star cellular ant
Tint-5% front/double 5% layer on rears
6000k high and low beam HIDs
Quad beam headlight mod
JDM clear/black projector headlight housings
JDM clear/black front turn/parking light housings
JDM clear/black tails
Tinted 3rd brake
Mechanical/performance:
6.0 LQ9 swap
Magnacharger Radix 112 supercharger w/2.85" pulley
Dual heat exchangers for intercooler
Lingenfelter GT2-3 cam
Comp Cams LS6 valve springs
Pinned crank pulley
Pacesetter lt headers
Cat delete
True duals exiting through a pr of 40 series Flowmasters
BlackBear custom PCM tune
Hypertech 160* t-stat
S&B cai
NGK TR6 plugs gapped @ .035
Dual 16" electric cooling fans w/adj thermostat
Custom dual elec fan shroud
TB coolant bypass
Transgo corvette servo
Fluidyne Extreme HD trans cooler
SSBC big brake kit (larger rotors, 4-piston calipers, and stainless steel lines)
3/5 suspension drop (McGaughy's dropped spindles and DJM rear coils)
Toxic Shock drop shocks (soon to be replaced with Bilstein HD)
DJM rear axle travel mod
KYB steering stabilizer
Energy Suspension bushings
Interior and Audio/video:
Pioneer Avic-D3 dd dvd/nav head unit
Pioneer BT-200 bluetooth interface
Pioneer Ipod interface
Pioneer 910 XM sat/traffic tuner
Pioneer voice recog 6-disc changer (in cntr console)
Pioneer CD-RB20 aux ip-bus input
Pioneer ND-BC2 back-up camera
Alpine V12 300w 4-ch amp
Rockford 1000BD mono amp with Punch EQ remote
Two sets of Infinity Kappa 6.5" components custom mounted in front doors Infinity 6.5"co-axials (rear doors)
Alpine Type R 12" subs (2) in custom steel/mdf enclosure w/false floor
Monster Cable ZN interconnects
3000 watt Vector power inverter w/two outlets in rear of truck and one outlet and remote switch on pass side of center console
Dual battery set-up
PAC 250A battery isolator
1/0 ga cable with 200A ANL fuse and 4 way Maxifuse block
1/0 ga. battery to chassis ground cables
4 ga. neg batt to eng block
4 ga. alt to battery cable
DEI Directed dvd player (in cntr console)
DEI Directed 7" widescreen headrest monitors
8" monitor in custom housing in front cntr console
DEI Viper 5900 LCD paging remote start alarm integrated to heated seats, rear window and outside mirror defrosters
Window roll up/down
Remote headlight activation
DEI dual-stage motion, shock, and glass-break sensors
DEI piezos (2)
15 sirens and horn-honk (yes, it's
very loud when the alarm triggers
100 sq ft of Dynamat Extreme sound deadener and double layer of jute
Complete LED interior and puddle lights (super white)
Custom dome light assembly on liftgate
Blue LED gauges and HVAC control
Autometer dual a-pillar gauge pod
Autometer boost gauge w/blue LED
AEM UEGO wideband AFR controller/gauge
I think that's it...
