Custom Tune
Chizzychase
I am getting a custom tune done by a local shop they have a good rep I know multiple people that have trucks tuned there. What are some things I need to ask them about? He did talk about tuning the PCM for a E fan conversion so its already set up It just needs the pins plugged into the PCM, torque management, speed limiter and I am thinking about going with a 93 octane tune. Any input is welcome.
01ssreda4
Assuming you have stock internals in your engine? If so I would delete all torque management, up the speed limiter, delete all emissions codes, adjust PE percentage and ramp in rate, add timing, delete cat overtemp if you have headers, and adjust shift pressures to get a nice firm shift.
Chizzychase
Chizzychase
Torque management is a goner for sure, speed limiter is going up, internals are completely stock, I am going to a 93 tune so there will be a timing increase, and I am getting line pressure upped, as far as the PE percentages and ramp in rate you lost me there lol
Dont have headers at the moment but plan on going to longtubes and catless Y pipe in the future I know I will need a retune for that so I will probably wait to get all that done when I have the means to do the cam and spring swap on it like I want to.
01ssreda4
I would set PE around 1.13 enrichment, and bring it in quicker/sooner then stock.
#1taho
5150TAHO
niagara falls ont
Have you got your tune done yet ? I am done with my swap and tune it done. It's a complete night and day difference. Now I would like a bit more !!'n hahah
#1taho
5150TAHO
niagara falls ont
Power enrichment. Its a more aggressive fueling strategy for wide open throttle vs your normal cruising around.
Thanks
My tune is done and I mentioned everything except that !!! But the guy I used was very fussy and kept adjusting untill he was happy. He was very thuro and asked me exactly what I wanted. I also talked about what I thought I knew about tunning and he some of what he did was off of that. Over all I am very happy. Great power and Better miliage than the 5.3. Thanks for the help
Chizzychase
Chizzychase
Mine is done and I love it. They should come like this from the factory lol. Can't wait till my upgrade budget gets fatter for some long tubes, E fans, and a cam :D
joo3yy133
