Debadging
Fleetgeo
Not a good angle but the Denali badge on side door is removed I wanted a smooth look
05Single
afraid of the dark
Might take awhile, I know mine did. Wrap one end on a screw driver and the other end on another screw driver so you're not killing your fingers. Dont use one strand , i usually have 4 together as one thick strand. Move the line in a sawing motion cutting through the adhesive backing. Heat helps, so does letting it sit and soak in solvent for a minute or two. Solvent also creates a lubricant for cutting through the adhesive so you're not goin in dry (pun intended), cause it will heat up and break from too much friction.
MrBalll
West Texas
I let mine sit in the sun from about 1500 hrs. to 1630 hrs. then did it. Used one strand and went slow. Came off pretty easily.
juan84
Mounds view MN
a53bcad5ed1b3f58776e4dabb455d8b5.jpg330be2ad29d73748c9888de8b2c52e34.jpg862fd6b7bbfd3184a5a50f12b0eae924.jpg gotta love the eraser wheel de badged the tailgate in 10 min also remove the plastic window thing
sent from galaxy s6
Chadly14
