Just got some news I did not want to hear. I took my 02 Tahoe to the shop I have been using and they were going to do the driver's door upper and lower hinge pins. They just called me and told me that both front door hinge weld attachments at the body side are starting to crack and will need to be welded. I switched to this shop from a shop I used to be the service manager at because the tech's at the old shop were not being as thorough as this new shop. Plus, as it turns out, the owner of my new shop is a tech that I used to have at a shop I ran. I knew him to be very thorough and did not have comebacks. I was recommended to his shop and was surprised to see him, in a good way.
Anyway, back to the story, He caught the cracking welds and I am glad about that. He also told me my rear axle seals are leaking fluid and the pads are very thin. He took pics and sent to me on my cell. The old shop had just drained the rear diff fluid and installed new. I am the kind of guy, and so is the new shop, that would have looked for rear axle seal leaks when I am servicing a diff. Same on the front diff. He found as he was taking the rear calipers off to do a park brake adjustment. The thin pads found at same time. I ordered in the new AC Delco ceramic pads and hardware and the AC Delco seals. He measured the rotors and said they must have been replaced before I bought the Tahoe because they are very thick with plenty of meat to machine when he does the work.
My problem is that I don't weld and don't know of a good weld shop or body shop to do the hinge work. I am eventually going to paint this rig so after welding I am just going to have the person who does it just shoot some rattle can paint on them to keep from rusting.
Oh well, back to the drawing board.
