Depo vs Sonar and then some other questions
DenaliAK
Colder than you
Alaska
Not that I'm aware of, other than the DEPO's are much cheaper to replace if you screw something up.
DenaliAK
Colder than you
Alaska
In general, yes, but I think in the case of the Denali lights it doesn't make much difference. I'd rather have used OEM headlights if I could have found a set for a similar price to the DEPO's.
BubsXL
TN
easier to retrofit (im MOST cases not all)
hidplanet.com
What makes it easier? I plan to use something along the lines of the Bi-xenon Morimoto Mini Stage III Kit (D2S) kit in the Denali housings which I assume is small enough to give me little trouble in the way of making them fit.
BurbyRST
