I'm looking to generate a detailed "go-to" or "pinned" post for converting/upgrading 5.3/6.0/6.2 trucks with LSA blowers. Including every nut and bolt necessary, proper spark plugs and gap, correct accessory brackets, injectors, pump, and part numbers for everything. For most people it will probably serve more as a heads-up or even deterrent on the project (realizing by the time you have acquired everything needed you're likely just shy of a brand new TVS kit), but for others with access to cheap / discounted parts or whatever, it could be a solid guide...
So (if it's allowed), to get started, if anyone has a parts list going or information to add, toss it into this thread and I will continue to "re-work" this initial post to serve as a detailed guide. If not, well, the mods can spank me.
Thanks in advance.
Thanks in advance.
