DIY light up logo
mazdawg(Mikey)
HGIC(head ginger in charge)
Lancaster SC
ok fellas heres how i do the light up logos. im sure there may be a better way of doing it, but this is effective. this will be a logo thatll fit donyukons nbs console if he decides to get it
i took some lexan and sanded it with my da sander and 180 grit paper. then i applied a sticker to it to work as a template
i painted it with a can of trim black paint and pulled the sticker off
i took a dash pocket i had laying around and cut it down and narrowed it
i put the led inside of the pocket and glued it to the backside of the lexan
and there you go! a lighted logo
from there the easiest way to install from there is to hot glue it into the console or a two part epoxy
Gzes
the drifting 2dr
Wichita tx
It looks great. I ak guessimg its not too cheap since it looks like the strips are frok an autoparts store? Ebay has smd strip rolls for cheap
mazdawg(Mikey)
mazdawg(Mikey)
Lancaster SC
I had the lights in my toolbox from a previous project that never left the ground lol. Also if you cut them in half you can solder some wires on the leftover piece and reuse it. That gets 4 uses out of a pack
Vettexan
