does zero compression in cyln #3 mean engine replacement?
99tahoesc
I know nothing about this kind of issue but Pep Boys is telling me that I need a new engine after they did a compression test and found that #3 has zero compression. They have already replaced wires, plugs, cap, dist, coil, module, ect....
Can anyone tell me something different than replacing the engine?
If I do have to replace the engine what should I expect to pay?
Thanks, I just feel like I might be getting ripped off by Pep Boys.....
muncie21
Did someone pull the valve cover and rule out damaged valve train or cam issues? Zero compression could also mean that you have a valve stuck for some reason.
AtomicHoe094
Atomichoe094
cleveland, OH
SURE! dont go to pepboys :) lol sorry for being a smart ass
But perhaps rings are gone or the rings could be stuck
any trouble codes? symptoms? whats going on with it?
retorq
Kingman AZ
If rings are "gone" you will still have a lil compression, it'll bleed off.
You would have to have a REALLY bad valve either bent or held open due to improperly adjusted lifter or rocker arm or something like that ...
They could have a bad compression guage too I guess.
I guess the good news is that you have a bunch of new ignition components to go with your new engine. LOL
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Id get a second opinion from a better source. Dealer maybe or get a compression kit and do it yourself. They are not that expensive
faze
British Columbia
It depends why you have no compression and if you trust this place. Having zero in one and the rest are ok is a little wierd. It's worth going the second opinion route here...go to a gm dealer is my suggestion.
If you need a new motor get a rebuilt one thru gm...they're not a bad price; don't bother getting your's rebuilt.
JKmotorsports
Austin, TX
I'd check to make sure a valve(s) isn't stuck open before anything else.
elianymanol
