All of these bulbs were burnt out on my truck. The ones I took out all said 168 but I've heard a lot of folks on here mention the 194 bulb. Which is the correct one. I guess the 168 has a slightly higher wattage but will not last as long? Thanks.
door switches will have a slotted fitting on the bottom. when you pull it out you will see the bulb in it. size specs:
http://tahoeyukonforum.com/forum/showthread.php?t=1352
194 bulbs are easy to find
Right, I got those. Maybe I should have made a different thread. I'm now looking for the door panel switch bulbs, the ones for the window switches, lock button, etc.
Yeah I'm a doofus and should have read the whole thread before replying I'll do some research on this as well. I'd like to do this upgrade on my 98
