Door panel courtesy light, which bulb is it?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
yes. pull the front face of dash off a bit and reach behind it to squeeze the switch connector to unlock it and pull out. that and the 4wd if had. when you get the entire face off you will see a twist on socket on the switch.
Tbruz
Windham NH
Derekjl,
that headlight switch bulb is the same one i'm looking for and have a pic posted on the Bulb -D-Needed post.
Did you ever get the pn for that bulb?
Thanks
Tbruz
EDIT: I ended up using AcDelco bulb 12383436; while a slight bit taller bulb than what I removed, it fits and works perfectly.
Thanks
Tbruz
D
derekjl
they pop out by prying underneath them. just do it slowly so as not to break it with excessive force.
Tried to pry the back window switch covers off to replace the bulbs. I'm afraid if I try any harder something is going to break. Is this definitely how they come off or should I remove the ashtray and try to pry them out from the inside?
blueshroom
