Dorman 610-530 Wheel Studs on 2010 Tahoe LS 4WD
ARealBlackNinja
Hey everyone,
I'm looking at upgrading to **fully threaded and extended wheel studs** for my **2010 Chevrolet Tahoe LS 4WD**, and the **Dorman 610-530** caught my attention. I’ve checked the specs (M14-1.50 thread size, 15.90mm knurl diameter, 78mm length), and they seem like they could work, but I haven’t found any confirmations of fitment for my specific model.
Has anyone here installed the 610-530 on their Tahoe or Yukon? Did you run into any issues with the **knurl fitment or overall length clearance**? Any feedback would be appreciated before I purchase. THANKS!
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Before you do anything you should know the knurl size of the OE studs. The knurl size on the OE is slightly smaller at 0.623" or 15.8242mm. If you put a bigger knurl in that hole it could cause a crack. Seen it happen before. But, the sizing, in mm, may be minimal enough that it would not crack.
Next, the stud you are talking about is for a rear only wheel application of numerous Ford truck years that are dually's. The dually/Dorman stud is also about 1/2" longer from shoulder to end.
So, knowing all that.....WHY!
Welcome to the forum from Oregon.
petethepug
Michael
SoCal
@FastGas changed his front wheel studs out for a BBK on his 08 Esky EXT. I’ll likely have to do the same. I found that ARP has longer studs too.
22BlackDenali
