Drivers seat is loose?
rolfsent
rolfsent
Cincinnati
---------- Post added at 10:56 AM ---------- Previous post was at 09:15 AM ----------
[/COLOR]
mine rocks bit with the same effect and it is play in the sliding rail. i really have to fix it. i dont want to be driving one day and pull an american airlines and suddenly become instantly reclined.
Lol
rolfsent
rolfsent
Cincinnati
So my loose drivers seat just became dangerous. I was leaning back to get my wallet out of my back pocket and I heard a loud pop pop pop and my seat reclined. I pulled it forward and now it just slowly reclines by itself and makes a whole bunch of popping noises (worse than before). Looks like I'm making a trip to pull and pay in the morning.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you work for american airlines?:D sorry to say your seat is gone. strip it for parts where you can, if you cant just get a part that would fix it.
rolfsent
rolfsent
Cincinnati
All the seats at the yard were trash. It also said they had a Denali and was just a mislabeled Yukon.
gmcconvert
my 97 has same issue. drivers seat with power track. if I lower the seat all the way then no play but when its 1/3 way up or more then rocks when stopping/bumps/etc. It also has enough slop to jam the power adjustment sliding seat forward or backward. I can see joint in rail where metal is worn to sloppy tolerance. I thought would be a simple bushing fix but the more i search it looks like a crappy design and will need to change the rails out. I assume others have had this problem. ???
---------- Post added at 08:17 PM ---------- Previous post was at 08:16 PM ----------
Sounds like you went the smart route and swapped for the 99 rails. i believe those are the beefier, redesigned rails.
rolfsent
rolfsent
Cincinnati
Maybe it wasn't so smart because the seat is a 99 and that's what failed.
kaoticlife
Port St Lucie, Florida
my "99" has the same recline type slop in it. I can reach back and pull forward on the seat and it moves about 2 to 3 inches forward. I need to look into fixing this.
