Drivers seat is loose?
rolfsent
Cincinnati
My 97 Yukon drivers seat has developed some looseness (tilting) to it. I can move the seat about a half inch to an inch just by pushing on the head rest. When taking off and coming to a stop it does the same thing and when it moves it makes a popping noise and its starting to get on my nerves pretty bad.i saw there is a fix for the NBS trucks but not for obs trucks. Any ideas on how to fix this????
This is all I could find and it's for the NBS http://www.tahoeyukonforum.com/forum/showthread.php?t=43406
Donnie Yukonie
Yates Caretaker
Should be 4 bolts you can tighten that holds the seat to the truck you can start there
Sent from my DROID4 using Tapatalk 2
rolfsent
rolfsent
Cincinnati
I'll check those but I honestly don't thinks its that. The frame is tight but the actual seat is what's loose.
Gzes
the drifting 2dr
Wichita tx
The welds broke. Quiet common. Just tack them back up and your good. Or get a non broken seat
qukon 95
it's worn linkage with in the seat but i had a crack in the metal
where it bolts to the power seat track i fixed it with no more clicking
sounds but the play was still there. i got a set driver & pass power seats out of a 99 the tracks are heavy duty $50.00 out the junk yrd.
I think thats the yr they started using these tracks also there heated
seats to.(don't work).
rolfsent
rolfsent
Cincinnati
Well my drivers seat is out of a 1999 Suburban. It's a heated seat and I didn't have one before and now the heated seat works. I'll pull out the seat on my next day off and check it out.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
mine rocks bit with the same effect and it is play in the sliding rail. i really have to fix it. i dont want to be driving one day and pull an american airlines and suddenly become instantly reclined.
RepublicanRebel
