Driver's side door handle
PH99TAHOE
Janesville, WI
Door module is not too bad to remove. Here's how to do it once the door panel is off:
1. Make sure window is completely rolled down.
2. Remove all the screws around the door module, including the large one in the lower right corner.
3. Remove wiring from around module and the door speaker.
4. Remove door actuator rods from latch and handle.
5. CAREFULLY lower the module assembly out of the door, keep a hand on the glass so it doesnt bend or break off the brackets.
That's it, biggest thing is to be mindful of the glass because you don't want to break it.:)
bowtiefreak
bowtiefreak
No Quarter
Near Philly
so I fianlly did this...in the rain. Not a fun job. Took about 2.5 hours or so taking my time. I would say it is a job just about anyone can do. Watch the videos from 1a auto on youtube to get some pointers.
1ATony
Thank's for checking us out. If there's anything you guys need from me you can always shoot me a PM.
Tony
GoTigers
Charleston, SC
Replaced my driver's side handle yesterday. With the help of the 1aAuto video and some of the posts it wasn't that bad. The actual act of the replacing the handle took about 10 minutes. It was removing the inner panel that took up the majority of the time. I ended up taping the glass like the video and was able to move the panel forward enough to drop the window rollers out of the frame. This allowed me to leave the majority of the wiring in place.
Thanks again for all of the help.
rabbiporkchop
Pennsylvania
they are not bad to do just u fight them alittle. the one bolt in the crease of the door, then another in behind the panel , so take the panel off and near where the handle would be is kinda like a hole and u catch the second bolt there. as for the lock it just a tab like i switch would , push it in and it slides right out and just clicks right into the new one. on the lock if u take any nuts of u are doing it wrong. should only take u like 15 minutes
It took me an hour.
mrwes
Black95
I NEW IT JUST COULD NOT BE AS HARD AS THOSE WHO LOVE TO TALK AND PLAY WITH YOU TUBE. I MAY HAVE SPENT MORE TIME GETTING IN HERE TO THANK YOU THAN THE HANDLE SWAP. THANK YOU SO VERY MUCH YOU DONE GOOD BY ME mrwes
jerryjoe28
That Guy
cabot AR
Just a fyi I have done 50+ of these and they are never the same. Sometimes they are super easy and sometimes it can be a pain in the @$$
Tssonebay
