During cold start, auto trans sounds like it bangs out of gear???
89Suburban
Bull in the china shop
SE PA
During cold start, auto trans sounds like it bangs out of gear or a clutch pack or band releases??? This is freaking me out. The truck will jerk a bit too. Only happens once in a great while but still unnerving. Truck runs and drives fine other wise. Whenever I park I always put it into park and set parking brake. Could it be the torque converter or the TC clutch?
Mickey_7106
Bay Area
Fluid level ok? Also are you holding the brake while setting the parking brake?
89Suburban
89Suburban
SE PA
Fluid level fine. Yes I hold the brake, throw it in neutral, set the parking brake and take the load of the vehicle drive train, then put it into park and turn off.
89Suburban
89Suburban
SE PA
Of course it hasn't done it since that post.
PG01
Up here to the right
Of course, and it probably never will again.... thats just our luck ..... or non-luck or un-luck or ****-a-duck????
I'm curious if it does it if you cold start in neutral?
Jerk truck... never had that but ive had jerk chicken...
89Suburban
89Suburban
SE PA
Never started it in neutral cold or hot.
****-****-fuckity-****-****.
Westernstar8806
