Easiest aftermarket lights under running boards? 2024 Tahoe
ZackTahoe
I have 2024 Tahoe LS and I love the look of lights under the running boards when doors open/unlock
Any suggestions for aftermarket parts to do that? Would it be difficult wiring ?
Stbentoak
There is really nothing like the OEM that would hold up and be dependable. And not look like you cabbaged it on....
When these T1s first came out, do you remember the guy on here that hooked up lights inside and out that synched with the music and he posted videos of people dancing next to his car with the lights "moving" to the music? That had to be 2-3 or more years ago, wonder how his are holding up?
probably not going to be "easy" per sey on a 2024, but essentially you just need to run a wire from the interior lighting output on the bcm thru the firewall and under the truck to attach to whatever lights you decide on
GMCChevy
You can buy LED tape light that is meant or at least sold for underbody use. You'll need to find that lighting circuit to connect to.
Champ74
