ECM fuse popping.
clayton191
Hey everyone,
I have a 2015 GMC Yukon 5.3 SE - I have been getting a blown 30Amp ECM fuse every time I turn the ignition on. There are three connectors to the ECM. If I disconnect those, insert a new fuse, and turn the vehicle ignition to ON, the fuse does not blow.
Does this sound like a bad ECM? or should I diagnose further (aka, could the fuse pop if I have a ground on an O2 sensor thats connected to the ecm)?
If it is a bad ECM - What is required for me to get a new ECM? Just show up at the dealership and buy one? Do they need to be reprogrammed.
I do a lot of shade tree work on old jeeps but this may be beyond me. Just trying to avoid having it towed....
ReaperHWK
Sounds like a short somewhere. I’d turn the car on with each connector connected one at a time and see which one causes the fuse to blow. Then I’d meter each pin in that connector to groind and see which one is shorted.
C
clayton191
So it is the middle ECM harness (not blue, not grey, the black one) - I've tried to find the wiring for that module in the diagram. Not having much luck, the wiring doc is 1295 pages haha. Eventually I'll find it I suppose - does anyone know off hand what I could connect?
I read from the ground pin on that connector to each pin hole - and I had an OL for each one.
I appreciate the help guys, sorry for the slow response, I tossed my hands up and left if for a few days....
Are you using the shop manual at AllDataDIY?
robert_543
