So I recently acquired a 2000 Tahoe the previous owner was in the middle of swapping out the motor driven radiator fan for dual electronic fans from a newer model silverado. I was helping in the swap as the vehicle became mine midway thorough the conversion. At first you would need to plug the fans in under the hood after starting the car and unplug after turning it off. We finally got around to wiring them up to a toggle switch however when doing so we wired one connection to an ignition fuse under the steering wheel. After wiring everything up we took it on a test drive and after a few minutes on the road the gauge cluster cut off it was receiving no power but the truck was still running. After we brought it back we unplugged the wire from the fuse, which was still intact. But now it will not start and we can not figure out why when you turn the key it does not even try to turn over there is no signal getting to the engine telling it to start has anyone had a problem like this doesnt have to be the same cause as mine but if you have had electrical problems that sounded like this I would love to hear how you went about figuring out what the problem was or how it got fixed please it is very urgent Im about to start work and need a vehicle we spent forever getting the transmission back in working order only for this to happen and it has us scratching our heads we dont even know where to start
