Electric Fans Vs Clutch Fans
Romey10
Yup took doin a little homework, and some investment put I love my Tahoe and it’s not going anywhere so it was all very much worth it to me.
George Cobos
question on these efans can they be installed and use a radiator probe to turn on at certain temps? or does the computer have to be tuned no matter what?
Romey10
No they don’t have to go through computer. I have hptuners software so that was not a problem for me.
George Cobos
cool thanks for the info guys any suggestions on this reason im asking is not to try and do it the easy way it is because there is no one within 100 miles where i live to do the computer tune and the temps here are extremely high so idle sux we are usually a 99 degrees an higher pretty much til mid september
Romey10
cool thanks for the info guys any suggestions on this reason im asking is not to try and do it the easy way it is because there is no one within 100 miles where i live to do the computer tune and the temps here are extremely high so idle sux we are usually a 99 degrees an higher pretty much til mid september[/QUOTE
My suggestion would be to go with a stock efan setup off something around 2005,6,7 Tahoe,Silverado set up vs a Flex o lite setup first for cost second I’m pretty sure the FOLs draw more amps and thirdly you should just be able to bolt on assembly if you have a 34” radiator already, rather than the way FOL has you do it. You can maybe get the wiring side temp controller from FOL and the Amazon factory plugs for fans. Depending on what alternator you have now you mite have to upgrade it. Mostly do some homework and you’ll see what I’m talking about with everything. Good luck
It’s totally worth it!!!
Jack1805
