Electrical issue
TaboltB2015
Went to the hardware store and came back out and had service 4wd, traction control and abs... i could barely get the Tahoe to move all gauges were zero other than the battery voltage. I have another form stating the same problem.... I have replaced battery cables, fuse box’s, tried another battery, tried new BCM, Added grounds.
kbuskill
NE. FL.
Did you check for any codes?
A Tech2 would be super handy to have when it's doing that.
I didn’t have time to mess with it I took it back to the shop that had it last
kindly report back what they find out so we can share this information, thanks good luck
i'm particularly interested to find out if has anything to do with the fuse box or still a ground issue somewhere.
T
TaboltB2015
Last time they replaced the fuse box because the starter relay was moved around so much that supposedly it bent the fuse box terminal? If you search my username you should be able to find the other form from May 2018
ya I think I think I read thru all that before just curious what they say this time around
T
TaboltB2015
Who knows I’m just tired of this dang thing! I have it for sale and I’m wanting to get a Jeep Wrangler.
mahergscott
