Electrical - where to begin
rockola1971
Indiana (formerly IL)
you can pretty much test it yourself by starting it up turn everything on lights, hazard switch, heater full blast, radio, windshield wipers on full speed, defroster. and anything else
then take your meter and see how many volts are at the battery terminals, then also check at the alternator output, it should match what is being sent to the battery or be very close to the same should have no more than 1-2% difference
Yes. A true check Requires the alternator to be loaded down. You should see roughly between 13.8-15.0 vdc at the battery with engine running at idle and alternator loaded.
Moosemoon
Moosemoon
Easy to remove alternator and take it to get bench tested. I believe most retail auto parts stores can do this for free. Not suggesting to get a replacement, yet. Hopefully the tester puts it on a scope or other device rather than just looking at voltage.
I take to one parts place today. They said they can test voltage and diodes while in the vehicle. Couldn’t get there today. Hoping tomorrow
Moosemoon
Moosemoon
This has been a great thread so far. Lots of good info. What was/is the overall condition of your truck as far as corrosion goes? I can't think it would be too bad in ID, unless they do use salt out there.
My speculations are as follows:
1. Corrosion from elements over time. Also, corrosion from natural moisture, especially if it sat for 2 years outside, or on grass or gravel. Vehicles parked on non-solid surfaces are more prone to moisture related corrosion issues from my experience. I'd go over Chassis ground points with a wire brush, coat area with dielectric grease, and reassemble. Use a star washer if provided. Also check the main cables for discoloration and tightness of crimped areas.
2. Modules that died slowly from sitting so long. The steady decline can mess them up
. Or, a jump start from stone-cold dead as well. Have the battery load tested.
3. The alternator idea was something I didn't think of, but I would put down as a relevant idea. You could make sure the battery is fully charged, them remove the power wire from the alternator (tape it up, or put it in a non-conductive covering. Run the vehicle for a short time and see if anything changes. If you have a weak battery, this test won't work well.
4. Do a general inspection of wiring harnesses for pinched areas, worn areas, etc. Being that the trans and motor were gone through, it's a possibility something didn't get put together correctly. Look for proper routing near heat shields, mounting points, etc. Also look at connections to make sure they are in fact "clipped" together properly.
I absolutely HATE electrical gremlins. My hat is off to you for having the gumption to learn and tackle this yourself. Best of luck! Hopefully this brain trust (meant in sincerity) of a group can help you get it figured out. LOL
Thank you so much. I am learning tons. You have put alot of what is scattered in my various notes and brain in a good summary.
is there anyway to print this thread?
The Yukon has always been parked on firm ground but not garaged. Idaho has been using some sort of ’salt’ solution for the past 5 years or so. New DOT guy rumored to be getting rid of it! YAY. Give me crushed lava any day.
When I look under the Yukon, it looks reasonable to me. I used to wash the under carriage regularly in winter. But the last 2 winters it’s been in the guy’s shop. So I would say exposure to the salt experiment here has been minimal. That said it IS 22 years old. And from what I understand this generation is notorious for corrosion at critical points.
I would think the guy who did the work would have checked all that but based on all the other details that he didn’t address, I am pretty sure he did not do much.
Thanks again.
Moosemoon
Moosemoon
Moosemoon
Moosemoon
In my opinion, if it were only a ground issue, there would be some consistency to the issues you are facing. There doesn't seem to be any. This leads me to believe it is a positive issue. Also, I have seen similar issues in four other vehicles, one of which was a Crown Victoria (the other three were a 2003 Sierra Denali, a 2004 Silverado 2500, and a 2005 Suburban 2500).
The idea of a ‘positive issue’ is interesting. Not sure I know how to go about testing that? Please forgive me, but I give new meaning to the word novice.
Thanks
Moosemoon
Moosemoon
Ok I have a question.
would any of you allow the original guy to work on this again?
tators50
