Engine Diagnostic Help
pwilliamson1548
Don't use Premium gas on a 8:1 engine. Especially with lower compression. 93 octane burns slower than 87 it causes hard starts, rough idle, gasoline blow by, and cylinder wash down. Run a tank of 87 to see if it helps. Also your Timing chain could be stretched causing the slight backfire and rough idle. That's a lot of miles for a gas engine.
Sent from my Nexus 6 using Tapatalk
SunlitComet
OBS Jedi-Do Good
unknown at this time.
premium and mid grade are doable in the obs vortec if the ignition map was modified for performance reasons. just wanted to put that out there. i use mid grade because of my ignition map.
kahnor
