Engine light 2006 Yukon XL
Woodblocker55
Does engine light come on when it's time to change oil ? I seen the change oil then 2 days later engine light came on .. But I know in Minnesota artic strange things happen in the cold . Looking at -18f for tomorrow night .
Sent from my LGL84VL using Tapatalk
mijohnst
Mine doesn't, I don't think. Did you try just clearing your oil life display? I think it's all manual and doesn't do anything to check the oil life. Did you put an OBC on and look to see if there are any codes?
Woodblocker55
Woodblocker55
I will put my adapter on today and see what code it is thanks for the replys . I will keep you posted. It did it at a intersection low idle going around a corner.
rockola1971
Indiana (formerly IL)
You are right. There isnt a oil life sensor in our pans. I know Cadilac cars had that sensor. The cluster display message for oil life is just triggered by a timer/mileage counter within the display.
Woodblocker55
Woodblocker55
ewgaul
