Engine Oil Overfill
OBSTheBest
I wholeheartedley agree with @OR VietVet. Invest in a few tools and always do your oil changes yourself. I had a nightmare incident once.
About 9 years ago, I took my truck to Jiffy Lube and had them do a "simple" oil change. Turned out the oil filter they placed on it looked like it was for a car. It was tiny! Seemed to be starving the engine of oil and causing the motor to chirp internally. Was so strange too, because you could pull the dipstick out and the chirp would go away. As if it was relieving internal pressure? Never confronted them and went home and did my own oil change. All was fixed.
Boy, do I regret not confronting them, but I did not want to make any enemies that day.
Never again have I let anyone else change my oil.
Hope no serious damage has been done to your Vortec. Please keep us updated, if possible.
homesick
The Best Me I Can Be
I've gotten past the point of doing my own oil changes and lawn mowing.
For oil changes, I've found a small independent mechanic's shop. It's two younger guys in an old 2 bay ex-gas station. It costs more than going to 'We Be ****** Oil Changes And ****' does, but I trust these guys. Their vehicle inspections are geared to maintaining the truck, not to selling me more parts.
Not bragging, but I'm even getting a bit hit and miss about checking their work.
joe
E
Eddie_Tahoe
I have the tools and have done my own oil before. Unfortunately just not set up for it now. Honestly fine paying someone for it to build a relationship for bigger stuff and keep the truck in good order. Always found that a good investment. These last few years have just been real hard to find somebody to trust.
I'll let y'all know how it turns out. What should I keep an eye out for once I get the level straight?
Thanks again!
OBSTheBest
Thanks again!
For starters, just keep an eye on the oil pressure and make sure your motor is not making any sounds out of the ordinary while running.
Maybe even pull the dipstick after a few hundred miles and check for any metal shavings in the oil. That would be a sign of some serious damage, though.
I'm sure some others with more knowledge than me (very novice) may chime in.
Hope this helps a little. Thanks!
GMT800 SUV/Trucks
homesick
Some how, some way, either do the oil change yourself or find a trustworthy shop, friend recommendations and a personal meet and greet helps. I always use a magnetic drain plug and encourage others to as well. Periodically do an oil analysis with these guys: https://www.speediagnostix.com/shop/p/standard-drain-sample-kit
What do you think of this, as a cheap, quick and easy, down and dirty, metal trap...
Stick a magnet to the outside bottom of the pan, near the plug. Remove it at oil change to let the oil flush any collected shavings.
I thought about this in the '70s, when, AFAIK, magnetic plugs weren't common. I've just always wondered how much good it would do; where it ranks on the 'better than nothing' scale.
joe
GMT800 SUV/Trucks
joe
Sounds doable, BUT, when the metal gathers there is always a sludge effect at the metal area. If you use a magnetic drain plug, that comes out with the plug. If you use your method, there MAY be some of that left in the pan. But, it is a "better than nothing" idea.
JayySalas
