So I posted this before as a muffler rattle - but then I ruled that out after replacing the muffler so new thread.
I get a rattle (which I thought was the muffler) with the symptom listed below.
Ok. Back to drawing board on symptoms.
Not speed dependent but appears to be rpm dependent.
Can get it to come in at 40 mph and 70 mph.
Key seems to be rpm - 1500 seems to be the sweet spot to bring it in but anywhere from 1250-2000 and it comes in. Acceleration only, no deceleration. Not in first, second or third. If you hard accelerate from stop it does not come in.
Cruise control really amplifies it. Cruise make engine sit right around 1500 and it comes and goes, comes and goes.
Sounds like a piece of metal vibrating as air flow goes by. Like it is resonating.
AFM does not seem to play into this. Does not happen when shifting to/from V4/V8.
I appreciate any theories.
