Going to pull a stock 5.7 out of a 1996 Tahoe. I plan on unplugging the wiring harness and going from there. Obviously, I will remove the hood grille, radiator, fan shroud. Anything else I should remove to pull the engine? Are the bellhousing bolts a PITA to get to? Any pitfalls or cautions?
Please, any advice or suggestions would be appreciated! Really need this remove/ install to be quick and painless...
Thank you!
Thank you!
